Distance in zone
 (using v. 6.0.169.0)
Hi I need help on getting the length of a route inside multiple zones /areas.
Please see routingtest.zip in the ftp folder.
Press the test2 button.
Now the route total distance is 295 meters
And i need to get the length of the route zone1 & zone 2 to match to total length.
- Niels
Hi Niels,
I would recommend taking a look at one of our Wiki Code samples that deals with clipping named "Clipping_On_Line_Layer". You can find this sample at this link: wiki.thinkgeo.com/wiki/Map_S...Line_Layer
Using this sample as a basis you should be able to clip the line that resides inside of Zone 2 and get its distance and also clip the two segments that are outside of Zone 2 and get their distances.
