Hi Ethan,
Thanks for your response.
The problem comes as soon as the project is opened.
The 2 buttons are a relic of an old test project (I could have deleted them).
It’s weird that you have not managed to reproduce the problem.
You have installed version 12.0.5000 of sql?
What kind of Collate Sql do you have for your Sql Server?
in our projects, we use Latin1_General_CI_AS. Is it the same for you? (Maybe the difference in behavior can come from there?)
You can see all Collate Sql listed by SQL with this query :
SELECT name, description
FROM fn_helpcollations()
The name of the collate that we use is Latin1_General_CI_AS
where name like ‘Latin1_General_CI_AS’
Regards.
Steph.
