GetSpatialDataType SQL Generated for SQL Server 2008 is incorrect for tables and views in non default schema
This is in regard to Version 5.5 services edtion.
I've noticed that the SQL generated to find out the spatial data type of the column of interest for a view or table for SQL Server 2008 is not actually correct (when the table/view is in another schema).  In our application the GIS data is kept in a GIS schema for eg with a feature layer defined as:
var worldLayer = new MsSql2008FeatureLayer()
                                    ConnectionString = @"Data Source=DB;Initial Catalog=GISDATA;Integrated Security=SSPI;MultipleActiveResultSets=true;",
                                    CustomGeometryColumnName = "Extent",
                                    IsVisible = true,
                                    Srid = 4326,
                                    TableName = @"GIS.vwData"
When rendering etc The SQL that is generated is this:
SELECT
 allTypes.name
FROM
 sys.columns allColumns,
 sys.types allTypes,
 sys.all_views allViews
WHERE
 allColumns.object_id=allViews.object_id AND
 allColumns.user_type_id=allTypes.user_type_id AND
 allTypes.system_type_id=240 AND
 allViews.name='GIS.vwData'
union
SELECT
 allTypes.name
FROM
 sys.tables allTables,
 sys.types allTypes
WHERE
 allColumns.object_id=allTables.object_id AND
 allTypes.system_type_id=240 AND allTables.name='GIS.vwData'
This won't find the column as the schema name is not included in the sys.tables.name field (or in our case the sys.all_views.name).  It doesn't seem to affect anything as I'm guessing it defaults to geometry (which is what we are using) if it doesn't find anything.
Am I doing something wrong in the feature layer setup or is this a bug?  Also out of interest what would happen if there were two spatial columns in the table one geog and one geom (we don't do this nor have any plan to)?
Neil.
Neil,
 Thanks for your question, I believe this is a bug and you are right that we default to the geometry if it doesn’t find anything.    If you had two spatial columns one geometry and the other geography the layer would ignore the geography column.
Clint,
Thanks for your quick response and also answering my question of interest.
I'll keep an eye out for this being fixed in a future release.
Neil.
Hello Neil,
 Any more questions please feel free to let us know.
