Highlight multiple shapes when clicked
Currently my map will highlight an object/shape on the map when the user clicks on it. But when the user clicks on a second shape, the first shape is no longer highlighted and the second shape is. What I would like to have happen is if both the first and second shapes are both highlighted. Essentially highlighting multiple clicked shapes. So is there a way to add the second to the highlight layer of the first, without clearing it out?
Hi Chad,
Attached show how to highlight multiple shapes. Please check it out.
HighlightMultipleShapes.zip (1.6 MB)
Peter
Yup, thank you Peter.
Hi Chad,
You’re welcome!
Peter
One last thing on this. If the user clicks on a feature that is already selected/highlighted, how can I remove the clicked feature from the highLightLayer?
Got it. Had to change to the following. If you know of anything more elegant please let me know.
foreach (Feature feature in selectedFeatures)
if(highLightLayer.InternalFeatures.Contains(feature.Id))
highLightLayer.InternalFeatures.MoveToBottom(feature.Id);
highLightLayer.InternalFeatures.RemoveAt(0);
else
highLightLayer.InternalFeatures.Add(feature.Id, feature);
Hi Chad,
Please try the following code:
            if (highLightLayer.InternalFeatures.Contains(feature.Id))
                highLightLayer.InternalFeatures.Remove(feature.Id);
            else
Peter
