JPEG2000RasterLayer doesn't load
using Daily Full Production 9.0.0.638 or Daily Full Development 9.0.632.0 I’m not able to load a JPEG2000RasterLayer.
Unmanaged Dependencies is Map Suite Unmanaged Dependencies 9.0.520.0.msi.
If I Change the files Resolution MapSuite will load the file.
It seems to me that there is a Memory Problem. Originaly the file is 13.9 MB.
After reducing Resolution the file will be load with 5 MB of size.
Is there any update or fix for Version 9?
Regards
Hardy
Hi again,
tried to run the same with MapSuite 10 will raise a System.AccessViolationException.
Hi Hartwig,
We tested our JPEG2000 sample for v10 and it works fine.
Please refer this sample https://github.com/ThinkGeo/Jpeg2000Sample-ForWinForms for detial.
If you still meet this issue, could you please provide us a sample, so our developer will handle it.
Hi Don,
i have checked your sample with our data. Getting the same error.
Tried to upload…failed because 13.9 MB…
Any other way to send you my data?
Regards
Hardy
Hi Hartwig,
Please send data to forumsupport@thinkgeo.com. And our developer will continue work on this issue when received the data.
Bill
Hi Bill,
mail was send to forumsupport.
Regards
Hardy
Hi Hardy,
Thanks for your data, we had reproduced your exception.
Our developer will look into it.
Hi Hardy,
Our developer had reproduced this issue, and find that’s because a 3rd part dll.
We contact the library provider and get the a good news, that the dll have a new version which should had fixed this bug.
We need some time to integrate the new version 3rd part dll and do some test, it need takes some days.
Please wait our update on this.
Hi Hardy,
This issue had been fixed, you should want to update the two packages as below:
ThinkGeo MapSuite Jpeg2000 Layer 11.0.0-beta002
Map Suite Dependency - LizardTechMrSid 11.0.0-beta002
You can find them in one or two days from NuGet.
