LayerSwitcher Replacement
Our application require us to provide functionality similar to what the LayerSwitcher does, but with the added functionality of reordering layers. I implemented this using ExtJS TreePanel. It works pretty weel with the exception that the map never updates even after I issue a layer.redraw(true) command. Below is the code:
function layerControl() {
    var map = Map1.GetOpenLayersMap();
    var store = new GeoExt.data.LayerStore({
        map: map,
        layers: map.layers
    var layerList = new GeoExt.tree.LayerContainer({
        layerStore: store,
        leaf: false,
        expanded: true
    var layerTree = new Ext.tree.TreePanel({
        enableDD: true,
        root: layerList,
        listeners: {
            'checkchange': function(node, checked) {
                var overlay = map.getLayer(node.layer.name);
                overlay.visibility = checked;
                overlay.initVisibility = checked;
                overlay.redraw(true);
    var win = new Ext.Window({
        title: 'Layer Configuration',
        width: 200,
        height: 180,
        layout: 'fit',
        items: [layerTree],
        buttonAlign: 'center',
        buttons: [
            { text: 'Apply' },
            { text: 'Close',
                handler: function() {
                    win.close();
    win.show();
Any help is greatly appreciated
Chris
Hello Chris,
Looks like the code is right, could you please make OverlaySwitcher map tool enable, so you could check whether other LayerOverlays overlap this LayerOverlay. The code likes below:
 Map1.MapTools.OverlaySwitcher.Enabled = true;
