Link to Web Map Service
 How do you connect to a WMS and show this on the base map as a layer?  In teh features it says this is possible, but I cannot find out how.  Thanks,
 Hi James,
Thanks for your post and welcome to MapSuite World, please get the latest version 6.0.0.338 or 6.0.338.0 first fromhelpdesk.thinkgeo.com , here we fixed 1 bug on Wms stuff, then I guess there are two ways to add WMS:
1. Use a WMS plugin, attached is the sample of the plugin. Please build it and copy the dll to “C:\Program Files (x86)\ThinkGeo\Map Suite GIS Editor\Map Suite GISEditor\Plugins”
2. Use dynamic language to fulfill it, dynamic function is in here:
Then type in the popup window with the code in “Post11167SampleForDynamicLanguage.txt” attached.
The reason of not using wms as a default base layer is wms depends on the internet and sometimes it will cause our GisEditor stuck. We will fix this problem in the near future.
Hope it helps,
001_Post11167Sample.zip (5.77 KB)
001_Post11167SampleForDynamicLanguage.txt (941 Bytes)
thanks will try that out
Hi James,
 You are welcome and don’t hesitate to let us know your queries.
