Loading ENC files
I’m trying to load the file that you can download from here: http://www.charts.noaa.gov/ENCs/Agreement.shtml?US5CA80M
I create a new NauticalChartsFeatureLayer and pass it the file US5CA80M.000, but it throws an error when the map refreshes after adding that layer to an Overlay.
My map unit is in Meters and I’m using the current projection for all my layers:
Proj4Projection proj4Projection = new Proj4Projection
    InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326), //wsg84 unprojected - all data will be in this format
    ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(3857)  //mercator projection
Tried projecting the nautical charts layer but same error. Is there something specific I have to do for these types of layers?
Hi Dan,
Here is a sample about how to use NauticalChartsFeatureLayer: https://github.com/ThinkGeo/DisplayNauticalChartsSample-ForWebApi/
And here I build a sample for the data you mentioned:
9327.zip (345.3 KB)
