Map Suite WMS Server Edition Deployment Guide
There is a part of Map Suite WMS Server Edition Deployment Guide :
There are two kinds of projects in the installation directory. “CSharp WMS Server” is for deploying a server while other projects are used to consume that service as clients.
Run the WMS Service
Here are the steps to deploy the WMS service.
  1. Open the “CSharp WMS Server.sln” solution and set the “Admin.aspx” as the default startup page.
  2.
  3. ...
Unfortunately, there is no “CSharp WMS Server.sln” in the installation directory "Map Suite WMS Server Evaluation Edition 5.5" after install it.
Hello Ion,
 Thanks for your post and sorry for the inconvenience.
 The wiki data is old and it changes a lot now, there isn’t CSharp WMS Server.sln anymore, you can find the CSharp VS2010 Web.sln in the Map Suite WMS Server Full Edition 5.5\HowDoISamples, run it and you will find three projects in it.
 CSharp VS2010 WebEditionSample
 CSharp VS2010 WmsPlugins
 CSharp VS2010 WmsPluginService
 If you set the CSharp VS2010 WmsPluginService as the startup project, you will see the ThinkGeo Wms Server Admin and you can check the Capability now.
 We will update the wiki soon.
