Multiple Multipoint Shapes
I have two multipointshapes, with one showing on top to the other. What I want to do is remove the lat/lon points in the lower shape that also are in the upper shape. Short of looping through both collections and removing points manually, is there an easy way to do this?
Dib
Hi Dib,
Our spatial query API is for handle the shape for example combine, split, different etc.
Your requirement should work by loop the vertexes.
