Panning while in trackmode
This seems like I am missing something, but when I am setting my trackmode on the trackoverlay to anything other than None, I lose my ability to pan the map.  That makes it very difficult to draw large and accurate boundaries for our users.  They complain about having to zoom out, then zoom in to move the screen.  What can I do to enable the pan while in a track mode?  I can use middle mouse button or right mouse button to start the pan if necessary and leave the left mouse button as is.
Hi Jake,
I think there are two ways for this case: One is using the right mouse button to pan and the other one is still using the left mouse button but with some complex.
Here is the first way:
wpfMap1.TrackOverlay = new MyTrackInteractiveOverlay();
public class MyTrackInteractiveOverlay : TrackInteractiveOverlay
        protected override InteractiveResult MouseDownCore(InteractionArguments interactionArguments)
            InteractiveResult result = base.MouseDownCore(interactionArguments);
            result.ProcessOtherOverlaysMode = ProcessOtherOverlaysMode.ProcessOtherOverlays;
            return result;
The second way:
private void HandleMapControlMouseMove(object sender, MouseEventArgs e)
           if (e.LeftButton == MouseButtonState.Pressed && trackOverlay.TrackMode == TrackMode.Line)
               trackOverlay.IsPan = true;
       private void HandleMapControlLeftButtonUp(object sender, MouseButtonEventArgs e)
           if (trackOverlay.TrackMode == TrackMode.Line) trackOverlay.IsPan = false;
       private void HandleMapControlMouseLeave(object sender, MouseEventArgs e)
   public class CustomTrackOverlay : TrackInteractiveOverlay
       private bool isPan;
       public bool IsPan
           get { return isPan; }
           set { isPan = value; }
       public CustomTrackOverlay()
           : base()
           if (!isPan)
               return result;
           else
               InteractiveResult result = new InteractiveResult();
               return new InteractiveResult();
       protected override InteractiveResult MouseMoveCore(InteractionArguments interactionArguments)
           if (!isPan)
               InteractiveResult result = base.MouseMoveCore(interactionArguments);
               return result;
           else
If there anything confused, please let us know.
Troy
As below is a update.
The code as below work for the first solution, left button to track and right button to pan.
        : base()
        if (this.TrackMode != TrackMode.Polygon)
            return result;
        if (interactionArguments.MouseButton == MapMouseButton.Right)
        return result;
            return result;
        return result;
Don
thanks for this code snippet. I would have never found a solution on my own.
I had to change it a bit, to recognize fast mouse clicks.
                InteractiveClickInterval = 10;
            return result;
            return result;
        protected override InteractiveResult MouseUpCore(InteractionArguments interactionArguments)
            InteractiveResult result = base.MouseUpCore(interactionArguments);
                InteractiveClickInterval = 400;
            return result;
I could however not get the code to facilitate the middle mouse button (i.e. mouse wheel click). Just changing the if-statement does not suffice.
Did anybody find a solution for this?
Peter
Hi Peter,
Our map don’t support pan by middle button, so it’s not easy to implement that.
If you don’t assign other function to right button, you can do hack like this based on my previous code.
public class CustomExtentOverlay : ExtentInteractiveOverlay
public CustomExtentOverlay()
: base()
        if (interactionArguments.MouseButton == MapMouseButton.Middle)
            interactionArguments.MouseButton = MapMouseButton.Right;
        return result;
        return result;
Map1.ExtentOverlay = new CustomExtentOverlay();
Don
Hi Don,
thank you for your answer.
But: Ouch! That’s really a hack!
Luckily I could get my users to accept to use the right mouse button for panning the map in track mode…
Best regards,
Peter
Hi Peter,
I am glad to hear that’s helpful.
Any question please let me know.
Don
