Raster image overlaying on winforms map
I am trying to overlay a .jpg image on winforms map using GdiPlusRasterLayer class… but either i am getting some distortion or some parameter issue in testing machine…
And i wanted to know the difference between following two lines…
  1. GdiPlusRasterLayer rasterLightening = new GdiPlusRasterLayer(Application.StartupPath + @"\Data\as.jpg",_proj.ConvertToExternalProjection(new RectangleShape(-180, 90, 179, -89)));
  2. GdiPlusRasterLayer rasterLightening = new GdiPlusRasterLayer(Application.StartupPath + @"\Data\as.jpg",new RectangleShape(-180, 90, 179, -89));
    rasterLightening.ImageSource.Projection = _proj;
Please help me on this…
Ashok
Hi Ashok,
What’s the problem using your code? Does that the jpg file don’t rendered succeed?
I think you need set the mapunit to decimal degree for your code 1 and make sure your layer had been added into map.
So, please provide us more information or directly upload your jpg file, we can help you look into this.
