User machine errors when using NOAA Weather Warnings Feature Layer
Hi Dib,
I have received your email and download the project succeed, any update I will let you know.
Hi Dib,
We reproduced that, we cannot make sure whether that’s related with your code. But you mentioned it works well in some earlier version, so our developer will check the code change log first.
Any progress will let you know.
Hi Dib,
We just found where is the problem, both your “with” and “without” installer, include a extra folder, which prevent our map find the correct dlls. You can see my screen shot here:
It contains an old dll which built in 2014, delete this folder, then your “with” installer works well.
I guess you also include some older merge module in your installer, which should caused this problem, could you please double check your installer and see how to solve that?
