What kind of major vendors Map data Sets are supported?
Are there any major vendors Map Data Sets are supported ?
Not separate files as .tab or .shp, but ESRI Map Documents ESRI .mxd or MapInfo Workspace .wor or some similar like a project format.
We have some Map Data in ESRI and MapInfo format. How could we use them in your WMS Server as a complete data sets, not by loading separate .shp or .tab files ?
If it is not realized, what kind of other convertable from ESRI or MapInfo data set format could you suggest to use ?
Ion,
 Thanks for your question, unfortunately the .mxd and .wor files are proprietary to ESRI and MapInfo and we can’t read them in Map Suite.  However you can setup your zoom levels and rendering to match what you were using with these products via the rendering code.
