Context Menu sub menu
Liam,
 Just let you know we are still working on it. Sorry for inconvenience.
Hi Liam,
I’m sorry to bother you but I have to confirm that which issue you’re referring to in the latest post. It seems to me that what you’re talking about is the position issue of ContextMenu in the second sample you provided. If this is the case, in my opinion, the article Khalil posted at 11-24-2010 has provided the information about how to it.
According to your code sample, I guess it has nothing to do with the previous issue. Sorry if I don’t get this right, but if you’re referring to that one, the AutoPan property of Popup, the workaround is still under investigation, and it will take us a lot of time to figure it out since there are a lot of situations we need to take into consideration, so that it won’t bring extra inconvenience out of this one.
HI James,
Apologies for not making it clear. It was the context menu issue that I was referring to but we could not resolve using the fix that suggested by Khalil and we are investigating a work around hence the post.
Liam
Liam,
I have done a test using the solution suggested by Khalil. Everything goes well. What I did is to remove the “” from master page. Here is a complete sample for you.
001_ContextMenuSample.zip (256 KB)
 Hi James,
Thank you. Will review.
Liam
You’re welcome.
