Custom point styles
I’m trying to override the DrawCore function in a class that inherits from PointStyle. Basically I’m looping the features in that DrawCore and doing some calculations to create a circle around the point feature. But how do I actually draw the point at the end?
For example, I see canvas.DrawText and canvas.DrawImage, etc., but what do I use just for a normal point using this style?
Hi Dan,
You can modify the feature collection, and pass the modified collection as parameter to base.DrawCore(features,xxx).
It should works I think.
Do you mean I modify the feature collection in my overriden DrawCore function and then call base.DrawCore? Maybe you have an example handy for something like this: A normal point style, but a circle drawn around it using an inherited pointstyle class and overriding the DrawCore function.
Hi Dan,
I double check your requirement, and found you don’t need to write a custom point style for it.
You can just implement that like this:
            layer1.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(PointStyles.CreateSimpleCircleStyle(GeoColors.Green, 18));
        layer1.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(PointStyles.CreateSimpleCircleStyle(GeoColors.Transparent, 25, GeoColors.Red, 3));
        layer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
And it looks like:
You can adjust the size to make it follow your need.
Wish that’s helpful.
My custom point styles are more complex than that and each feature might be a different style. For example, I might have a feature that has a half-circle that rotates with the feature or maybe a line coming out of the feature at a certain angle. I do all these calculations in an overridden drawcore function in my custom point style.
Hi Dan,
Thanks to let me know more detail about that, here is a sample about how to implement the custom style, and you can write logic you want follow your requirement.
9535.zip (101.7 KB)
