Exception while drawing (3.1.299)
Patrick,
Please contact support@thinkgeo.com to request the version 3.1.299.72 DesktopEdition DLL package, I think our support will inform you how to get it in your Ticket.
James,
 I’ve an issue with that new version …
 The version I have deployed to my customer is 3.1.302.
 The version you are providing me is 3.1.299.72
 InstallShield is not deploying the new version because the version number is lower than the existing on end user desktops.
 I definitively need a 3.1.3xx with xx bigger than 02.
 Patrick.
Patrick,
 Sorry for inconvenience.
 After 3.1.299, we make the two branches and make the rule for the version number, one is for bug fixing that we use 3.1.299.x, the x is from 1 to 999, the other one is for new feature that we use 3.1.xxx, the xxx is the number start with 299 and keep increasing.
 So when we fix your previous bug, we shouldn’t send the 3.1.302 to you, but at that time the new rule was not carrying out, there was no 3.1.299.02 or 3.1.299.03, so I have no choice just can send 3.1.302 to you.
 If you have to the version 3.1.3xx with xx bigger than 02, I can contact our Support and send a new package to you. But after that, you still will encounter the same trouble as this time.
James,
 After testing 3.1.299.72 on the same PC that did not work with the previous version I now get a different exception, but still an exception.
 Please note that this exception occurs only when I set the tile on
 System.ArgumentException: Le paramètre n’est pas valide.
    à ThinkGeo.MapSuite.DesktopEdition.Overlay.Draw(GeoCanvas canvas)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x03e3d48bcfe7bb6c(IEnumerable`1 xa6f0db4f183189f1)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xff5b27c00f9678c2(RectangleShape x178b193eec228e6e)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x742ba885258f6c2c(RectangleShape xb35a33b423b17f65, Overlay x99251f66cdabc2ad, Int32 xa209325f5c895f7e, Int32 x7454a0d1965919b1, GeographyUnit xbb704b4400ce6f76)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x88c2a2d6d754e692(IEnumerable`1 xa6f0db4f183189f1)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xe3cee4adb9c72451()
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x9ac8c50f434f4b39(Int32 xb565f4681f05557a)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x4eb49068e137ed8f(InteractionArguments x195facd4ef5d753d)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xfeca3317d3c75bbb(Object xd9272088e65bd176, x6a8380ab1a7ebb4c xc2fd4c0ed406cdb7)
    à ThinkGeo.MapSuite.DesktopEdition.x5cd462d41be2f68a.OnMouseEvent(x6a8380ab1a7ebb4c e)
    à ThinkGeo.MapSuite.DesktopEdition.x5cd462d41be2f68a.AnalyseMouseUp(Double screenX, Double screenY, Double worldX, Double worldY, MapMouseButton mouseButton)
    à ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xd1e58e0ca2447b93(Object xd9272088e65bd176, MouseEventArgs xc2fd4c0ed406cdb7)
    à System.Windows.Forms.Control.OnMouseUp(MouseEventArgs e)
    à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    à System.Windows.Forms.Control.WndProc(Message& m)
    à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
James,
 I finaly found the difference between PC where MS works and PC where MS crash … it has to do with the screen DPI.
 If you set the screen resolution to 120 DPI, then all the tiling system crashes.
 Please make a test and provide me a fixed version.
 (I think it’s the same issue than gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6787/afv/topic/afpgj/3/Default.aspx#14776)
 Patrick.
Patrick,
I have replied you about fixed version at another post, please look at it:
Patrick,
 We have fixed this problem and you can download the version 3.1.398 to test again.
