FileGeoDatabase - Projection - Returns null
MapSuite Team,
The below code returns a null value for the projection string.
TheFileGeoDatabaseFeatureLayer = new FileGeoDatabaseFeatureLayer(TheFilePath, TheTableName, "OBJECTID");
TheFileGeoDatabaseFeatureLayer.Open();
    TheProj4Projection = TheFileGeoDatabaseFeatureLayer.GetInternalProj4ProjectionParametersString();
Opening up some of the files of the GeoDatabase using notepad I can actually see the projection string.
The following code also returns a null:
Projection TheProjection = TheFileGeoDatabaseFeatureLayer.FeatureSource.Projection;
I am using ThinkGeo.MapSuite.Layers.FileGeoDatabase.11.0.0-beta009
The data has been uploaded to my ThinkGeo drive space at: home/Chicago_Data/GeoFileDatabase/Airport
Dennis
Hi Dennis,
It looks the return value is correct.
If you are using any other table please let me know.
hi Ethan,
The below line of code returns a collection of table names. However, each name is preceded by a back-slash character as shown below in my application datagrid. My application programmatically used the names in the collection as-is. The problem is the back-slash. If the back-slash is present methods such as GetFirstFeaturesWellKnownType and GetInternalProj4ProjectionParametersString do not work. Remove the back-slash, as I’m now doing programmatically, and everything works.
Collection<string> TheGeoDatabaseTableNames = FileGeoDatabaseFeatureLayer.GetTableNames(ThePath);
To prevent future confusion it would be advisable to modify MapSuite GetTableNames such that leading back-slash is not included.
Dennis
Hi Dennis,
Thanks for your suggestion, I am not sure why the first slash is keep here, but I will let our development team knows your suggestion about it.
For now I think you can use this line to make it works in your scenario:
var tables = FileGeoDatabaseFeatureLayer.GetTableNames("../../AppData/Airport").Select(x => x.TrimStart('\\')).ToList();
Wish that’s helpful.
