GeoTiff Layer shifts when printing
Hi guys,
I am having a problem when printing a GeoTiff layer to Pdf. When a projection has been applied to the GeoTiff the image does not align with the other features in the map. If I create the Pdf and the GeoTiff does not have a projection everyting is fine.
[Here is how it looks without projection.][1]
[Here is how it looks with projection][2].
PageLayoutSample (Raster Projection Error).zip (118.5 KB)
I have attached a sample project. You will need to get the GeoTiff from the following link:
[LowerForty][3]
Thanks!
Steve
[1]: https://www.dropbox.com/s/6mgjm7e9y3yba79/GeoTiffWithoutProjection.pdf?dl=0
[2]: https://www.dropbox.com/s/dxaal2ung5fuogk/GeoTiffWithProjection.pdf?dl=0
[3]: https://www.dropbox.com/s/tew9zhfewuv6wjy/LowerForty.tif?dl=0
Hi Steve,
It looks the dropbox.com cannot be accessed here, if the file is too big to upload here, do you think I can download it from other website or you can upload it to our FTP?
Ethan,
I can FTP the files, how do I do that?
Thanks!
Steve
Hi Steve,
If you don’t have our FTP account, you can contact your sales to get it.
Then you can use 3rd part utility for example FileZilla to login the FTP by your account(that should be your company name), and you can upload the data into it.
After you upload succeed, please let me know what data you uploaded(sub folder name or file name), I can let our manager to help pass the data to support team.
Wish that’s helpful.
Hi Ethan,
Look in folder ‘GeoTiff Layer Shifts’ for file ‘Data.zip.’
Thanks!
Steve
Hi Steve,
I think we should had fixed it, please upgrade your package to https://www.nuget.org/packages/ThinkGeo.MapSuite.Layers.Printers/11.0.0-beta017 and test it again.
Ethan,
Thanks very much! The fix works well with the beta release. Do you know when the fix will be available in a production release?
Thanks!
Steve
Hi Steve,
Our developer had moved the change to release for you, please try this package: https://www.nuget.org/packages/ThinkGeo.MapSuite.Layers.Printers/10.5.2
