How to save/retrieve/edit/ delete mixed da using SQL2008 FeatureLayer
Hi Yale,
    I think the test engineer for the API should have the code for saving the tracked polygon shape together with its associated text data into SQL table, if the scenario I mentioned is the desired test case for verifying the SQL API functionality. I am afraid that the test code used in the URL is for another scenario irrelevant to the one I raised.
 Franklin
Franklin,
Thanks for your post and sorry for the delay.
Take a try on the attached sample showing how to save the tracked shapes into feature source. While, in this sample, I saved the tracked shapes into shape file instead of the SQL server Table for my SQL environment is still not prepared yet. I think according to the APIs we have discussed previously, just replaced the saved API from ShapeFileFetureLayer into MsSqlFeatureLayer should work for your case. Hope this sample can give you some idea.
Franklin,
I am sorry I missed the sample code, here it go.
Post8259.zip (10.8 KB)
