Carlos,
The API couldn’t entire the same without any different, we just keep them similar that user can easy to develop on other platform.
For TrackMode change event, I think you can check the TrackMode at the beginning of your operation, such as Mouse Down or Key Down or other event.
For the CustomInteractiveOverlay doesn’t work, is because the order of overlays are control the behaviors of each interactives. You can try to change the index of existing Interactive Overlays, you will found some overlay doesn’t work as well, so if you want to yours are working properly, you need to increase its priority that make the index less, such as you can try to move it to the first overlay in the collection.
Hi James thanks for answering,
I understand you try to make the API common between platforms, generally it is a good idea, but you lose some benefits of specialized features, in this case, having the track and edit logic separated only adds complexity to the solution.
Regarding the CustonInteractiveOverlay issue, it is the only one in the collection. Should I set the standard Edit and Track overlays to nothing? Do you have any code example of an integrated CustomInteractive overlay integrating both edit and track functionality?
Carlos,
I don’t know how to make you satisfied, I think there are some legacy, but as my poor knowledge, my responsibility is that solve user’s problem and give some suggestion to implement user’s requirement.
If some requirement are not implement by current API, we will consider to add new API, however you want to track shape and edit shape, I think we already provide TrackOverlay and EditOverlay to let user do it, you don’t need to combine them together. For example, if user want to create a CustomLayer to support any kinds of spatial data, what we can do?
Hi Carlos,
Just get response from our development team that they have resolved the "keyboard" issue, please get the latest version 6.0.49.0 or higher and have a try.
Btw, the attached is a demo related to the issue, before using it, please make sure the cusor focus is on the map control.
Best Regards!
001_KeyDownInteractiveOverlayExample.zip (9.96 KB)
Johny, I do not see the version of 6.0.49.0, only 6.0.47.0 ((
That’s great, and only three months after the bug was reported!!
Hello Alex,
Please check your helpdesk again, now the newest version is 6.0.50.0, if you can’t get it, let me know, I can send to you with email.
Gary, I do not see a new version of the library in Daily Production Builds. Only WpfDesktopEditionFull6.0.0.47DllPackage.zip.
You can solve this problem for me to see daily changes?
Alex, you are fortunate. Last build I see is 6.0.45.0
Posted By Carlos on 07-03-2012 02:29 AM
Alex, you are fortunate. Last build I see is 6.0.45.0 :)))))))))
Hello Alex and Carlos,
Thanks for reporting this, I can see this problem after I use some account to login, we will fix this issue and I will post here let you know.
Sorry for the inconvenience, we have fixed this problem, you will see the newest version after next build.
Please let me know if you still can’t get it.
