Hi Ethan,
Quite a bit has changed / been uncovered whilst investigating this problem so it might be easier to try and re-summarise the problem. The current situation is:
If I print a map with a mixture of raster and vector layers with a DPI higher than 100 (set for a PrinterGeoCanvas type object) it sometime works fine and it sometimes shrinks the raster layer to just sit in the top left corner of the paper.
The raster layers that respond correctly are of type NativeImageRasterLayer
The raster layers that have problems are of type MultiGeoRasterLayer (not a standard type but from a ThinkGEO example).
Additionally I have noticed that certain text, such as that used in title boxes (type LabelPrinterLayer) also suffers a similar fate to the raster layer and ends up very shrunk.
I noticed that the MultiGoRasterLayer overrides DrawCore and, by setting a breakpoint, I was able to check what canvas was being passed in. it looked to be the correct type but had a 96 DPI value and not the 300 DPI value set for the canvas. This makes me think that not all the layer attributes are being maintained between layer.Draw(printerGeoCanvas, simpleCandidates); and MultiGeoRasterLayer.DrawCore( … ). I am just guessing that something similar may be happening with LabelPrinterLayer.
Jonathan
