Simple Map not displaying when using MapViewSizeUnitType.Percentage
BaseMap.zip (2.0 MB)
I created a simple map using the following setting and it does not display:
<MapView Id=“map”
@ref="_mapView"
MapUnit="@ThinkGeo.Core.GeographyUnit.Meter"
ProgressiveZooming=“true”
Width=“100”
Height=“100”
MapViewSizeUnitType=“MapViewSizeUnitType.Percentage”
Code has been attached.
Hi James,
When MapViewSizeUnitType is not set, MapView uses Pixel by default. That means:
  Width="100"
  Height="100"
is rendered as 100px x 100px. Since this is an explicit pixel size, the map can still display
even if the parent container does not have a defined height.
However, when you set:
the same values become:
  width: 100%;
  height: 100%;
At that point, the map height depends on the height of its parent container. If the parent container does not have an explicit height, 100% has no valid reference, so the map area will not display correctly.
To make Percentage work, you need to give the parent container an explicit height. For example:
  <div id="map-container" class="map-container">
      <MapView Id="map" Width="100" Height="100"
       MapViewSizeUnitType="MapViewSizeUnitType.Percentage"
      </MapView>
  </div>
  .map-container {
      width: 100%;
      height: 600px;
  Or, if you want it to fill the viewport:
  .map-container {
      width: 100%;
      height: 100vh;
In short, MapViewSizeUnitType.Percentage can work, but only when the parent container has a real height for the percentage to reference.
