Access Violation reprojecting GoogleMapsLayer
Hi guys,
We are using MapSuite Desdktop version 9.0.0.401. We started using this version just a couple of weeks ago. Recently we noticed whenever we try to apply a projection to a GoogleMapsLayer an AccessViolation exception is thrown:
System.AccessViolationException was unhandled
HResult=-2147467261
Message=Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Source=MapSuiteCore
StackTrace:
at xRM=.2EM=.5EM=(Bitmap bitmap, Double[] sourceWorldfileData, String sourceProjectionString, String targetProjectionString, Double[] targetWorldfileData)
at xRM=.2EM=.4EM=(Bitmap sourceBitmap, RectangleShape extent, String sourceProjectionString, String targetProjectionString, RectangleShape targetMinExtent)
at ThinkGeo.MapSuite.Core.ManagedProj4Projection.ConvertToExternalProjectionCore(GeoImage image, RectangleShape imageExtent)
at ThinkGeo.MapSuite.Core.Projection.ConvertToExternalProjection(GeoImage image, RectangleShape imageExtent)
at ThinkGeo.MapSuite.Core.GoogleMapsLayer.9j0=(GeoCanvas canvas)
at ThinkGeo.MapSuite.Core.GoogleMapsLayer.DrawCore(GeoCanvas canvas, Collection1 labelsInAllLayers) at ThinkGeo.MapSuite.Core.Layer.Draw(GeoCanvas canvas, Collection1 labelsInAllLayers)
at ThinkGeo.MapSuite.DesktopEdition.LayerOverlay.DrawCore(GeoCanvas canvas)
at ThinkGeo.MapSuite.DesktopEdition.Overlay.sRM=(GeoCanvas canvas)
at ThinkGeo.MapSuite.DesktopEdition.Overlay.Draw(GeoCanvas canvas)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.dhQ=(IEnumerable`1 drawingOverlays, RectangleShape extent)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.dRQ=(RectangleShape drawingExtent, RectangleShape extent)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.lRQ=(RectangleShape extent)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.kxQ=(Int32 delayInterval, RectangleShape extent)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.Refresh()
at GoogleMapProjection.Form1.Form1_Load(Object sender, EventArgs e) in C:\Users\steller\Documents\Visual Studio 2010\Projects\ThinkGeo\GoogleMapProjection\Form1.vb:line 19
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
at GoogleMapProjection.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ThreadHelper.ThreadStart()
Any ideas?
Steve
Hi Setven,
Please try to download this package and install it.
https://ap.thinkgeo.com:5001/sharing/A5z5WdSC0
Wish that can solved your issue.
Thanks Don! Where can I find the merge modules for distributing the needed files with our application?
Steve
Hi Steve,
I think we won’t update the merge module before 10.0 release.
But if that’s hurry for you, please let us know.
We can build a version for you.
Hi Don,
For now it will probably be easier to just go back to the older version of MS. Do you know when MS 10.0 will be released?
Steve
Hi Steve,
I just know the new version will be release this year, and now is 10/20, so I think it won’t be too long.
