This topic also refer to the fact that when we use AdornmentOverlay, events like right click (context menu for a marker) over a marker won’t fire. nor you can close a popup shown over map layers.
As a work around it suggested to use pointer-events: none; for .olControlAttribution css class.
It also mentioned that it won’t work for IE (although i find this article for taking care of this, but i haven’t read it yet  ).
- Is there any progress on this issue after 1-2 years, so i can use?
- should I change the css on the fly? Or IsDefaultJavascriptLibraryDisabled(false)should be applied first, and then change the corresponding css from residented css file?
