Any way to split one feature into multiple using thinkgeo wpf
I have shape file which is having one area layer. I want to split that area into two areas, where as we can union multiple features into single by using AreaBaseShape.Union().
Hi satishchandra_noogur,
If your area is MultipolygonShape type, you can split them by multipolygonShape.Polygons.
If it’s only a polygon, we don’t have an API to split it, because the map don’t know how to split it.
But we have an open source project named GisEditor: https://github.com/ThinkGeo/MapSuiteGisEditor
It contains the split function, you can refer it.
Thank you, I found solution i.e., areabaseshape.split() method.
Thanks for your share, it split an area by the other feature, you can try to pass in a line shape as the 2nd parameter.
