We often have labels that contain newline characters and would like to be able to present these on screen centre aligned. There was an old discussion on this subject here:
and the solution reads like it should be pretty much what we need, but unfortunately it appears that the text is being trimmed to remove leading whitespace after the reformatting, meaning any label where the first line needs padding is getting that padding removed somewhere else.
What would be the correct way of achieving the desired effect now? or is there a way to suppress removing leading whitespace?
Jonathan
