The map stays white, but looking at the watchlist, it shows the backgroundbrush set to the correct color. I have the same exact code in the winforms version and it works. What could the issue be?
Thanks to let us know it, I tested it and also found the BackgroundOverlay don’t works in the latest version, I have let our developer know it and it will be solved after they back from vacation next week.
You can use the code as below instead of BackgroundOverlay:
map.Background = new System.Windows.Media.SolidColorBrush(System.Windows.Media.Colors.LightBlue);
We will check this issue ASAP, if there is any update, we will let you know here.
Before we fixed that, you can use this workaround Ethan mentioned above.
