Create polygon with just outline, no fill
Seems like a simple problem but I’m having trouble figuring out the solution to this. I want to create a polygon/areastyle where just the outline is shown, but the fill should be clear. So basically it would look like if I was just creating connected lines.
Edit: Here’s the constructor I’m currently using for making area styles:
public static AreaStyle CreateSimpleAreaStyle(GeoColor fillBrushColor, GeoColor outlinePenColor, int outlinePenWidth);
I thought I just had to set the fillBrushColor to GeoColor.StandardColors.Transparent, but that made the outline dissapear as well.
Hi Dan,
This code should works for you.
        AreaStyle areaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.StandardColors.Transparent, GeoColor.StandardColors.Black);
        shapeFileLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle;
        shapeFileLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
I’m dumb. The reason it wasn’t showing up is because I had the “name” being used in my columnvalues for this custom area style spelled wrong. Thanks again!
Hi Dan,
I am glad to hear this problem solved.
