Draw curve line issue
    I want to draw curve line. I have from -to point, radius in Nautical mile, center point. I have tried with draw arc sample but it did not work for me. Please suggest how to draw curve line using all these parameters.
Goral
Hi Goral,
 I think that’s a little complex.
 1. The hard part is, you should want to calculate a circle based on your parameters.
 2. Then you need to know the start point of the curve and the end point of it.
 3. Loop the outer ring (it’s a line end to end), find your start point and end point, then you can get all vertexes for your curve. Or you can try our GetLineOnALine function on the LineShape class.
 Wish that’s helpful.
   Thanks for reply. Can you please explain GetLineOnLine function in detail or provide some example?
Thanks & Regards,
Goral
Hi Goral,
I think you can create a custom CurvedLineShape which can save to/load from a WKT. Here is a simple example how to do it by creating a new shape from BaseShape. It should work for you.
    // The CurvedLineShape Class
    class CurvedLineShape : BaseShape
        private PointShape centerPoint;
        private PointShape startPoint;
        private double angle;
        public CurvedLineShape()
            : this(new PointShape(0, 0), new PointShape(0, 0), 0)
        public CurvedLineShape(PointShape centerPoint, PointShape startPoint, int angle)
            this.centerPoint = centerPoint;
            this.startPoint = startPoint;
            this.angle = angle;
        public CurvedLineShape(string wellKnownText)
            if (wellKnownText == null || !wellKnownText.StartsWith("CurvedLineShape"))
                throw new ArgumentException("The wellKnownText is not supported");
            LoadFromCustomWellKnownData(wellKnownText);
        protected override string GetWellKnownTextCore()
            LineShape line = new LineShape();
            line.Vertices.Add(new Vertex(startPoint));
            double radius = Math.Sqrt(Math.Pow(startPoint.X - centerPoint.X, 2) + Math.Pow(startPoint.Y - centerPoint.Y, 2));
            double startAngle = Math.Asin(startPoint.Y / radius);
            for (int i = 1; i <= angle; i++)
                double x = Math.Cos(Math.PI / 180 * i + startAngle) * radius + centerPoint.X;
                double y = Math.Sin(Math.PI / 180 * i + startAngle) * radius + centerPoint.Y;
                line.Vertices.Add(new Vertex(x, y));
            return line.GetWellKnownText();
        public string GetCustomWellKnownText()
            StringBuilder sb = new StringBuilder();
            sb.Append("CurvedLineShape(");
            sb.Append(centerPoint.X + " " + centerPoint.Y);
            sb.Append(",");
            sb.Append(startPoint.X + " " + startPoint.Y);
            sb.Append(",");
            sb.Append(angle);
            sb.Append(")");
            return sb.ToString();
        public void LoadFromCustomWellKnownData(string wellKnownText)
            string wkt = wellKnownText.Replace("CurvedLineShape(", "");
            wkt = wkt.Remove(wkt.Length - 1);
            string[] wkts = wkt.Split(‘,’);
            string[] data = wkts[0].Split(’ ‘);
            this.centerPoint = new PointShape(Double.Parse(data[0]), Double.Parse(data[1]));
            data = wkts[1].Split(’ ');
            this.startPoint = new PointShape(Double.Parse(data[0]), Double.Parse(data[1]));
            this.angle = Double.Parse(wkts[2]);
        protected override void LoadFromWellKnownDataCore(string wellKnownText)
        // The references.
        private void WpfMap_Loaded(object sender, RoutedEventArgs e)
            InMemoryFeatureLayer inm = new InMemoryFeatureLayer();
            inm.InternalFeatures.Add(new CurvedLineShape("CurvedLineShape(0 0,10 10, 90)").GetFeature());
            inm.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.Canal1;
            inm.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            LayerOverlay overlay = new LayerOverlay();
            overlay.Layers.Add(inm);
            Map1.CurrentExtent = new RectangleShape(-155.733, 95.60, 104.42, -81.9);
            Map1.Overlays.Add(overlay);
            Map1.Refresh();
Here is what looks like:
    Given curveline shape example throw below error.
     Error : ‘test.CurvedLineShape’ does not implement inherited abstract member 'ThinkGeo.MapSuite.Core.BaseShape.GetWellKnownTextCore(ThinkGeo.MapSuite.Core.RingOrder)
   Please throw light on problem.
Goral
Hi Goral,
Please change the method in attached code shown as following:
to
 protected abstract string GetWellKnownTextCore(RingOrder outerRingOrder)
instead, because the code I pasted before is based on the old version.
     Thanks for reply. I have tried to change accordingly but it is throwing some other errors. Is it issue of version?
Goral
Hi Goral,
 This code as below should works for the latest version.
                this.angle = angle;
                if (wellKnownText == null || !wellKnownText.StartsWith(“CurvedLineShape”))
                    throw new ArgumentException(“The wellKnownText is not supported”);
            protected override string GetWellKnownTextCore(RingOrder outerRingOrder)
                sb.Append(“CurvedLineShape(”);
                sb.Append(",");
                sb.Append(",");
                sb.Append(angle);
                sb.Append(")");
                string wkt = wellKnownText.Replace(“CurvedLineShape(”, “”);
                string[] wkts = wkt.Split(’,’);
        private void DisplayMap_Load(object sender, EventArgs e)
            CurvedLineShape lineShape = new CurvedLineShape(“CurvedLineShape(0 0,10 10, 90)”);
            string wktString = lineShape.GetWellKnownText();
            BaseShape tmpBaseShape = BaseShape.CreateShapeFromWellKnownData(wktString);
            Feature f = new Feature(tmpBaseShape);
            inm.InternalFeatures.Add(f);
            winformsMap1.CurrentExtent = new RectangleShape(-155.733, 95.60, 104.42, -81.9);
            winformsMap1.Overlays.Add(overlay);
            winformsMap1.Refresh();
   Thanks for reply. I have implemented new code suggested in previous reply. It is also giving below error.
   Error ‘test.CurvedLineShape’ does not implement inherited abstract member ‘ThinkGeo.MapSuite.Core.BaseShape.GetWellKnownTextCore()’
Goral
Hi Goral,
 What’s the version you are using?
 I am test with the latest version and it works well.
 Could you please download the latest version for test?
   Thanks for reply. Ya given code is  working with version 8. If as per my requirement I am changing angle and latlon point for some angle and some point its not working. I think need to change some logic in the code.
Goral
Hi Goral,
 Do you meant when you set different centerPoint, startPoint and angle this code cannot draw correct new curve or you think the three parameters is not so well for your requirement?
HI,
  Thanks for reply. Ya I am finding workaround for my requirement. For that I have tried to input different lat long point with different angles. In that it draws for some combination. When I debug and checked I found for some combination function is not able to find startangle and its returning Nan is vertices.
Goral
Hi Goral,
 The mainly logic is in the function GetWellKnownTextCore as below:
 So I think if you met some special scenario cannot be handled correct, you can add new logic here for handle them.
   Thanks for reply. Ok it will helpful.
Goral
Hi Goral,
 I am glad to hear that’s helpful for you.
