MapSuite MVC View Model
Is there a way to return a View Model that either inherits from Map or contains a map property so that we can not only return the map in the controller to the view, but also custom properties in the Map VIew Model?
public class MapViewModel
    public Map Map2 { get; set; }
private MapViewModel InitializeMap()
        Map map = new Map("Map1", new System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage),
                          new System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage));
        var myMap = new MapViewModel(){Map2 = map};
        //myMap.Temp = "this is a test";
        myMap.Map2.MapUnit = GeographyUnit.Meter;
        myMap.Map2.MapTools.Logo.Enabled = true;
        myMap.Map2.MapBackground = new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"));
        myMap.Map2.CurrentExtent = new RectangleShape(-12939426.6371, 6201997.4056, -7812401.86, 2626987.386962);
        // base map layers
        GoogleOverlay googleOverlay = new GoogleOverlay("GoogleOverlay", GoogleMapType.Normal);
        googleOverlay.JavaScriptLibraryUri = new Uri("https://maps.google.com/maps/api/js?sensor=false&key=" + GoogleKey);
        myMap.Map2.CustomOverlays.Add(googleOverlay);
        ShapeFileFeatureLayer zipCodeLayer = new ShapeFileFeatureLayer(PathFilename);
        zipCodeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(70, 220, 220, 220), 1);
        zipCodeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        LayerOverlay staticOverlay = new LayerOverlay("ZipCodeOverlay");
        staticOverlay.IsBaseOverlay = false;
        staticOverlay.Layers.Add("ZipCodeLayer", zipCodeLayer);
        proj4.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4269);
        zipCodeLayer.FeatureSource.Projection = proj4;
        ShapeFileFeatureLayer.BuildIndexFile(PathFilename);
        InMemoryFeatureLayer highlightLayer = new InMemoryFeatureLayer();
        highlightLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(100, 60, 180, 60), GeoColor.GeographicColors.DeepOcean);
        highlightLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        LayerOverlay dynamicOverlay = new LayerOverlay("HighLightOverlay");
        dynamicOverlay.Layers.Add("HighLightLayer", highlightLayer);
        dynamicOverlay.IsBaseOverlay = false;
        myMap.Map2.CustomOverlays.Add(staticOverlay);
        myMap.Map2.CustomOverlays.Add(dynamicOverlay);
        myMap.Map2.Popups.Add(new CloudPopup("information", myMap.Map2.CurrentExtent.GetCenterPoint()) {AutoSize = true, IsVisible = false});
        return myMap;
I think this person is trying to do something similar with a view model and are running into a similar issue where the ClickEvent is not able to accept a ViewModel, only the Map as parameter. Is there a way to pass the entire view model to the click event via the Map.ajaxCallAction ?
enter link description here
Hi Jmarshall,
Please refer the reply in post: Shapefile click event
