Need help with fdo extension to load a .dgn file
I just want to display a .dgn file on my map, this format is supposed to be supported, but I don’t know where to start.
I have installed the fdoextension using the merge module (8.0.0.150)
my code is very simple so far:
OgrFeatureLayer msl = new OgrFeatureLayer(al.FileNameSource, “”);
msl.Open();
RectangleShape r = msl.GetBoundingBox();
msl.Close();
this raises the exception “connect failed”
   à OSGeo.FDO.Connections.IConnectionImp.Open()
   à MapSuiteFdoExtension.GeoFdoFeatureSource.Open(String providerName, String connectionString, String idColumnName, String featureSchemaName, String featureClassName, String geometryColumnName)
Can you help me ?
Best,
Patrick.
Hi Patrick,
I have asked our developer about this, it looks we don’t support DGN file for now, and we haven’t tested to load this file format.
I think maybe you can try to load that by CADFeatureLayer.
You should need some files when test:
wiki.thinkgeo.com/wiki/File:MapSuiteCadX862014-07-28.zip
wiki.thinkgeo.com/wiki/File:MapSuiteCadX642014-07-28.zip
And if possible, could you please send us a sample of DGN file, maybe we can take test whether we can render it correct.
Don,
 you clearly state that this format is supported here: thinkgeo.com/forums/MapSuite/tabid/143/aft/6203/Default.aspx
 it does not work with cadfeaturelayer too.
 you can find a sample file here: dropbox.com/s/f0vcyqkfn8hix9p/3701B152.dgn?dl=0
 keep me posted,
 Patrick.
Hi Patrick,
 It looks the website is created on 2009/08/26, but for now our code don’t support directly render the DGN file.
 Thanks for your data, I will let our developer look into the code to make sure whether we can support that.
 Any update we will let you know.
Hi Patrick,
 Sorry for the confusion there, I did a double-check today but seems like it’s not supported by Map Suite, I do a confirm with development team as well, I guess I need to say sorry for it. We will remove this format support from the website later.
