Projection to Openstreet map and Google map
I am using Thinkgeo Web Edition, there i am using different base maps like Openstreet map, Google map and Normal (Using Countries.shp shape files).
Some times I wanted to display my data in different projections based on place. I knew that I can do projection for Normal(Countries.shp file),
But is it possible to do same for Openstreetmap , Google maps… If so pls send me sample code.
Ashok
Hi Ashok,
The GoogleOverlay and OpenStreetMapOverlay don’t support re-project.
But the GoogleMapsLayer and OpenStreetMapLayer should support it, the API looks like this:
            proj4.InternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
            proj4.ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
            GoogleMapsLayer google;
            google.Open();
            google.ProjectionFromSphericalMercator = proj4;
            OpenStreetMapLayer osm;
            osm.Open();
            osm.ProjectionFromSphericalMercator = proj4;
But we cannot make sure the tile looks so well because it’s reproject the tile image.
