Hi Andrew,
Please download the “Map Suite WmsServer Edition Web How Do I Samples” I mentioned in post 7927 at first.
Then download the attached pre.zip (1.4 MB), this file is the pre-generated tiles with watermark, bu default please unzip it into disk D.
And you can open the DisplayASimpleMapWmsLayerPlugin.cs file then replace the GetMapConfigurationCore function by the code as below:
protected override MapConfiguration GetMapConfigurationCore(string style, string crs)
        // Get the directory to the sample data
        string worldLayerFilePath = Directory.GetParent(Directory.GetParent(AppDomain.CurrentDomain.BaseDirectory).FullName).FullName + Path.DirectorySeparatorChar + "SampleData" + Path.DirectorySeparatorChar + "Countries02.shp";
        // Create the world layer from a shapefile and add a style to it
        ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(worldLayerFilePath);
        worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
        // Create a MapConfiguration and add the layer to it
        MapConfiguration mapConfiguration = new MapConfiguration();
        mapConfiguration.Layers.Add("WorldLayer", worldLayer);
        FileBitmapTileCache cache = new FileBitmapTileCache(@"D:\", "pre");
        cache.TileAccessMode = TileAccessMode.ReadOnly;
        mapConfiguration.TileCache = cache;
        return mapConfiguration;
I tested that with our latest dll, it works well.
