Winforms Trigger MouseMove Event ThinkGeo 13 VB.NET
Hi ,
We are migrating from thinkgeo 8 to thinkgeo 13 . We have some features where it requires map mouse move event to be triggered and based on the position of cursor on map some features are implemented .
Using thinkgeo 13 I am not able to trigger mousemove event to get the position of the map .
Please provide any documentation or samples related to this .
Thank You,
Anusha
Hi @anusha,
Probably the best reference is our ‘HowdoI’ samples that can be found here. Once you run the samples, check out the 'Display Map Mouse Coordinates sample that shows how to accomplish this.
You can also check out this blog post that shows you how to tie into the MouseMoved event in the TrackInteractiveOverlay.
If you have a specific question or a sample .sln that shows your exact issue, you can post it here or send it to support@thinkgeo.com and we’ll be able to provide more guidance.
John
