WPF Map Draw Exception
I develop an application using VB and Mapsuite 10 for WPF. There are several overlays (one with shape files, one with vehicles…). I have set Overlay.DrawingExceptionMode = ThinkGeo.MapSuite.Drawing.DrawingExceptionMode.DrawException to every overlay that I use, because I don’t want my app to enter break mode. Is there a way when an exception is drawn to know which overlay is the cause of the exception?
Hi Marios,
  1. If you are debugging it, you can set the mode to throw exception, then you can know which overlay it is.
  2. You can set the event layerOverlay.DrawingException or layerOverlay.DrawnException, and see what’s the sender of it
  3. You can see the base map works well, just comment the overlay which you make sure render OK, it’s the exclusion method.
Wish that’s helpful.
