i have added point layer on my road's layer but i cannot display. first it gives error of index file i have created that file but still it cannot display. i do not know how to set extend of two layers
Thanks for your post, your code has no problem, just one thing, you can using one overlay for both Line layer and Point layer instead two overlay for each one.
So what’s the product version are you using? Could you please check your line shape file, if the features inside is really line. Like you can using MapSuiteExplorer to open the shapefile and see.
i have also used individual overlay for both layers. but i didn’t work. my line shape file is displaying but that point shape layer does not display. i have send my shape file on the given email address
sir indivdually point layer is displayed but it cannot overlay on the line layer i am sending you my road shape file also on the given address kindly solve my issue
The sample data provided with the samples is designed for use only within the specific sample applications that are provided. Thus they are stripped of any unnecessary data which explains the lack of prj files.
By default MapSuite does not read prj files but it does have the facility to do so. Check out this link for information on using the ConvertPrjToProj4 method: gis.thinkgeo.com/Support/Dis...fault.aspx
At this time we do not have an appropriate description of these files and their exact contents. These are simply the results of the Generate Routing Index method.
