I have a big database with about 26Millions of GPS coordinates in decimal degree and I would like to convert inside the data base from decimal degree to Spherical Mercator World Map Kit.
What should the right process be? converting inside but I do not have the code or should I download a flat file and then do use ThinkGeo?
26.000.000 of GPS coordinates in Decimal Degree needed to
Jean,
Our map suite provide projection convert helper functions which can help you convert coordinates from decimal degree to Spherical Mercator. You can build a program connect to your database for export the coordinates and then convert the DD coordinate to Spherical Mercator coordinate and update the result back to database.
If you need some sample code for convert in map suite please let us know.
And our World Map Kit have a decimal degree set, if you don't need use Google Map or Bing map the same time, maybe you could choose the DD set.
Any question please let use know.
Yigit
