4 vertexes problem on tiles
Sometimes i rarely get this error message on some tiles. "The shape you provided does not pass our simple validation. A ring should has more than 4 vertexes." When i re-open the page, it renders normally. Did i miss something? Or my shp file is corrupted in somehow.
Tolga,
 Can you first check if your shape file is corrupted using the method shapeFileFeatureSource.Validate()? If the shape file is fine, this method returns 0 items, otherwise it returns which records are not supported and why is that.
 If your shape file passes the validation, it might be a problem occurring under certain operations. Can you give me a more detail description of that so we can recreate? If you can provide a sample that’s great!
