Hello. I try to integrated Map Suite to SharePoint 2013 application page but without any success. Everytime I get error 403. After debugging the code everything is OK and there is no error but page doesn’t load and I get 403 error. If I use this code on standard web page(without SharePoint) the page loads. But after I use this same code in application page for SharePoint 2013 I get 403. Hmm… I don’t know what can be a problem with this because in ULS(SharePoint) logs is nothing(only a 403 error). Can you please help me with this problem…Maybe some idea what can I try next.
Thank you very much for your help.
403 Forbidden in SharePoint 2013 Application Page
Hi Vladimir,
Sorry we don’t have more experiences about SharePoint, I did a search for “sharepoint 2013 http 403 forbidden”, it looks this error in SharePoint 2013 usually related with environment setting, and there are many solutions mentioned in the topics, maybe we can try them to see whether this error can be solved.
Thanks for your test, it proved our map can works in your machine, so we can exclude that.
I think then we should try some other AJAX pages in SharePoint for make sure whether everything works correct in SharePoint 2013 exception map control, so we can research deeper to go on looking for the reason.
the main reason behind this error is when an un authenticated user tries to make access to the server of SharePoint without obtaining the legal permission of the local admin.
you can fix this issue manually by trying steps as mentioned below;
§ Go to Windows Explorer and find the way to /bin directory of application of web.
§ Then go to the properties by doing right click on the folder
§ Switch to tab of safety and hit edit
§ Then go to add button and adjoin local server group valid users or even \ users
§ Now simply make selections to options like Read, List Contents, Execute, etc.
§ Finally hit OK to pertain the fresh settings.
§ Refresh the webpage, hopefully this time you will be able to browse as you desire
You may still be getting this error if so is the case then i would suggest you to apply for some third party tool that could solve the issue without any extra effort like SharePoint File Repair Tool.
Hi Ron,
Thanks for your share.
