A feature with col value NULL is not the same with a Feature with col value " "
Hello ThinGeo,
Here is an issue I found while reading a TAB file with TabFeatureLayer. While I browse my features with a GIS software and I see that some values are NULL, the aFeature.ColumnValue["xxx"] returns "". Not sure if the same happes on ShapeFeatureLayer as well. I did some reading on .net Dictionary
Can I hope for a fix on this issue or a work around?
Kind Regards
Yiannis
Hello Ioannis,
 Thanks for your post, which GIS software are you using? And could you please provide your Tab file, I can have a test on it.
Hello Gary,
Please find attached a fragment of the tab file I was using. When I tried this in Quantum GIS it returned NULL for column  CallSign. In MapInfo it returns BLANK. It might well be the Quantum GIS that got it wrong. However a check from you will not do any harm.
Kind Regards
Yiannis
002_001_Samples.zip (2.34 KB)
Hello Ioannis,
 Thanks for your data, I have tested it with Global Mapper, and the Column CallSign and ETA returns Blank too, so looks like it’s the problem of Quantum GIS.
 Please feel free to let us know if you have any more queries.
Thank you Garry,
I just wanted to make sure that this was the case :)
Kind Regards
Yiannis
Hello Ioannis,
 You are always welcome.
