A few questions
hello
I have some questions for you.
Is World Map Kit WmsWebOverlay only available in online status? isn't it possible in offline?
If purchasing Web edition, can you provide offline map?
I would like to know quality of Offline map, is it about same quality like WordMapKitWmsWebOverlay?
waiting yours
Thank  you in advance.
Best regards.
Hi TaeYoung,
 The World Map Kit is available in several options including:
 World Map Kit SDK - For use within Desktop, WPF, or server based Silverlight or Web based applications. This gives you complete control of the data and the required rendering class and would a great addition to a Map Suite Web Edition order.
 World Map Kit WMS Server - This allows you to serve the World Map Kit data through a WMS server with no additional software needed. This way you can consume the World Map Kit data through any comptible WMS client. With this version you host the World Map Kit dataset.
 World Map Kit Online - This option allows you to easily access the World Map Kit data using the Map Suite WorldMapKitWmsWebOverlay API. This version is freely accessible but contains a watermark. To remove this watermark you will need to purchase the Map Suite World Map Kit Online accesss product.
 Ths World Map Kit Online quality is identical to the World Map Kit SDK and World Map Kit WMS server products as they all use the same base rendering class and dataset.
