Hi Team,
How to add custom road closure in the route driving direction then will choose another route…
Tamilarasan.
Hi Team,
Tamilarasan.
Hi Tamilarasan,
Please visit our sample here: https://github.com/ThinkGeo/RoutingSample-ForWinForms
And you can find how to implement that in the sample: Routing Around Roadblocks.
Wish that’s helpful.
Hi Ethan,
Its help . I have one doubt If need route block that time only i raise event like
if (chkIsAvoidArea.Checked)
routingEngine.RoutingAlgorithm.FindingRoute += new EventHandler(Algorithm_FindingPath);
else
routingEngine.RoutingAlgorithm.FindingRoute -= new EventHandler(Algorithm_FindingPath);
Otherwise its not required right?..
Tamilarasan.
Hi Tamilarasan,
I guess you means whether the event RoutingAlgorithm_FindingRoute is still need to be used if you don’t want to avoid block feature.
From the logic of our sample, it looks yes, the RoutingAlgorithm_FindingRoute event only handle the avoid logic in this sample, so you don’t need it if you don’t need add block points.
