I have the following code and do not seems to able to get labels to show ??
Regards
Ewan
Private Sub New_Raster_Position(ByVal Unit_Name As String, ByVal Unit_Operator As String, ByVal Lat As Double, ByVal Lon As Double, ByVal Speed As Double, ByVal Direction As Integer, ByVal Status As String)
I suspect the problem is when you create the InmemoryFeatureLayer , you did NOT set the featureSource columns correctly.
Please try to add the following code when you create the inmemoryFeatureLayer
Dim c As FeatureSourceColumn = New FeatureSourceColumn("Unit_Name", "String", 0) Dim columns As New Collection(Of FeatureSourceColumn)() columns.Add(c)
Dim bitmapLayer As New InMemoryFeatureLayer(columns, New Feature() {})
OK I have the multiple icons now showing but cannot figure out how to labels them ??
Ewan
Dim IconPath As String = Get_GIS_Icon(Unit_Name)
If System.IO.File.Exists(IconPath) = False Then IconPath = AppPath & “\icons\gis\base.png” End If
Try Dim myMapShape As New MapShape(New Feature(Lon, Lat, Unit_Name))
myMapShape.ZoomLevels.ZoomLevel01.DefaultPointStyle = New PointStyle(New GeoImage(IconPath)) myMapShape.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
If Not iconLayer.MapShapes.ContainsKey(Unit_Name) Then iconLayer.MapShapes.Add(Unit_Name, myMapShape) Else iconLayer.Open() iconLayer.MapShapes.Remove(Unit_Name) iconLayer.Close() iconLayer.MapShapes.Add(Unit_Name, myMapShape) End If
Finally gisMAP.Overlays(“iconOverlay”).Lock.ExitWriteLock() End Try
gisMAP.Refresh()
End Sub
Public Class MapShape
Private m_feature As Feature Private zoomLevelSet As ZoomLevelSet
Public Sub New() Me.New(New Feature()) End Sub
’ Let’s use this as a handy constructor if you already have ’ a feature or want to create one inline. Public Sub New(ByVal feature As Feature) Me.m_feature = feature zoomLevelSet = New ZoomLevelSet()
End Sub
’ This is the feature property Public Property Feature() As Feature Get Return m_feature End Get Set(ByVal value As Feature) m_feature = value End Set End Property
’ This is the Zoom Level Set. This high level object has all of ’ the logic in it for zoom levels, drawing and everything. Public Property ZoomLevels() As ZoomLevelSet Get Return zoomLevelSet End Get Set(ByVal value As ZoomLevelSet) zoomLevelSet = value End Set End Property
End Class
Class MapShapeLayer Inherits Layer Private m_mapShapes As Dictionary(Of String, MapShape)
Public Sub New() m_mapShapes = New Dictionary(Of String, MapShape)() End Sub
’ Here is where you place all of your map shapes. Public ReadOnly Property MapShapes() As Dictionary(Of String, MapShape) Get Return m_mapShapes End Get End Property
’ This is a required overload of the Layer. As you can see we simply ’ loop through all of our map shapes and then choose the correct zoom level. ’ After that, the zoom level class takes care of the heavy lifiting. You ’ have to love how easy this framework is to re-use.
Protected Overloads Overrides Sub DrawCore(ByVal canvas As GeoCanvas, ByVal labelsInAllLayers As Collection(Of SimpleCandidate)) For Each mapShapeKey As String In m_mapShapes.Keys Dim mapShape As MapShape = m_mapShapes(mapShapeKey) Dim currentZoomLevel As ZoomLevel = mapShape.ZoomLevels.GetZoomLevelForDrawing(canvas.CurrentWorldExtent, canvas.Width, GeographyUnit.DecimalDegree) If currentZoomLevel IsNot Nothing Then If canvas.CurrentWorldExtent.Intersects(mapShape.Feature.GetBoundingBox()) Then currentZoomLevel.Draw(canvas, New Feature() {mapShape.Feature}, New Collection(Of SimpleCandidate)(), labelsInAllLayers) End If End If Next End Sub
Ewan
gisMAP.Refresh()
End Sub
End Sub
End Class
In order to label the map shape, you have to pay attention following 2 things: 1) Have to set the TextStyle for the MapShape. 2) When you add the feature to the MapShape, the corresponding column value has to been added for the target feature.
Following is some code snippet to show how to label a text “MapShape1Text” for MapShape1. Dim mapShapeLayer As MapShapeLayer = New MapShapeLayer()
Dim feature As New Feature(-104, 42) feature.ColumnValues.Add("MapShapeText", "MapShape1Text") Dim mapShape1 As New MapShape(feature) mapShape1.ZoomLevels.ZoomLevel01.DefaultPointStyle = New PointStyle(New GeoImage("..\..\Data\Cargo Plane.png")) mapShape1.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 MapShapeLayer.MapShapes.Add("1", mapShape1) mapShape1.ZoomLevels.ZoomLevel01.DefaultTextStyle = TextStyles.Capital1("MapShapeText") mapShape1.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
This is brilliant and has enabled me to get the job done with the following :
If System.IO.File.Exists(IconPath) = False Then IconPath = AppPath & "\icons\gis\base.png" End If
Finally gisMAP.Overlays("iconOverlay").Lock.ExitWriteLock() End Try
