Add labels to points
I’m showing vehicle locations on a map, and I’m now trying to add labels to the points. I’ve created a second EditInteractiveOverlay layer in order to hold the labels. I’m setting it up as follows:
01.EditInteractiveOverlay labelOverlay = new EditInteractiveOverlay();
02.                   interactiveOverlay.DragControlPointsLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.IsActive = false;
03.                   interactiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.IsActive = false;
04.                   interactiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.IsActive = false;
05.
06.                   //ValueStyle used for displaying the feature according to the value of the column “Type” for displaying with a bus or car icon.
07.                   ValueStyle labelValueStyle = new ValueStyle();
08.                   labelValueStyle.ColumnName = “UnitLabel”;
09.
10.                   // AVL
11.                   TextStyle unitTextStyle = new TextStyle(“UnitLabel”, new GeoFont(this._settings.UnitTextFont, this._settings.UnitTextSize, DrawingFontStyles.Regular), new GeoSolidBrush(GeoColor.FromHtml(this._settings.UnitTextColor)));
12.                   unitTextStyle.XOffsetInPixel = 20;
13.                   labelValueStyle.ValueItems.Add(new ValueItem(“U”, unitTextStyle));
14.
15.                   // Calls
16.                   TextStyle callTextStyle = new TextStyle(“CallLabel”, new GeoFont(this._settings.UnitTextFont, this._settings.UnitTextSize, DrawingFontStyles.Regular), new GeoSolidBrush(GeoColor.FromHtml(this._settings.UnitTextColor)));
17.                   callTextStyle.XOffsetInPixel = 20;
18.                   labelValueStyle.ValueItems.Add(new ValueItem(“C”, callTextStyle));
19.
20.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(labelValueStyle);
21.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
22.
23.                   labelOverlay.EditShapesLayer.Open();
24.                   labelOverlay.EditShapesLayer.Columns.Add(new FeatureSourceColumn(“LabelType”));
25.                   labelOverlay.EditShapesLayer.Columns.Add(new FeatureSourceColumn(“UnitLabel”));
26.                   labelOverlay.EditShapesLayer.Columns.Add(new FeatureSourceColumn(“CallLabel”));
27.                   labelOverlay.EditShapesLayer.Close();
28.
29.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.IsActive = false;
30.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.IsActive = false;
31.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.IsActive = false;
32.                   labelOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.IsActive = false;
33.
34.                   this.map.InteractiveOverlays.Add(“Labels”, labelOverlay);
When I try to place the label on the map, I use the following:
01.PointShape pointShape = new PointShape(unit.Status.Longitude, unit.Status.Latitude);
02.                        pointShape.Tag = unit;
03.
04.                        if (feature != null)
05.                        {
06.                            caOverlay.EditShapesLayer.InternalFeatures.Remove(feature);
07.                        }
08.                        if (labelFeature != null)
09.                        {
10.                            labelOverlay.EditShapesLayer.InternalFeatures.Remove(labelFeature);
11.                        }
12.
13.                        Feature f = new Feature(pointShape);
14.                        Feature fl = new Feature(pointShape);
15.
16.                        System.Diagnostics.Debug.WriteLine("X: " + pointShape.X + ", Y: " + pointShape.Y + ", Tag: " + unit.UnitId);
17.                        f.ColumnValues[“Type”] = unit.Agency.AgencyType + “-” + unit.Status.UnitStatusIndicator;
18.
19.                        fl.ColumnValues[“UnitLabel”] = unit.UnitId;
20.                        fl.ColumnValues[“LabelType”] = “U”;
21.
22.                        caOverlay.EditShapesLayer.InternalFeatures.Add(unit.UnitId, f);
23.                        labelOverlay.EditShapesLayer.InternalFeatures.Add(unit.UnitId, fl);
I’m not certain why the labels don’t display. The values are being added to the labelOverlay layer because I can see them listed in the collection but they don’t show up on the map. Any suggestions?
Hi Clay,
Thanks for your further information, attached is the sample code for your reference, would you please try it again
Best Regards
Summer
Post11894Sample.txt (2.18 KB)
Thanks for your help Summer. I finally was able to get back to this and your code helped me immensely. Thanks!
Hi Clay,
 We are glad to hear your problem is solved.
 Any question please let us know.
