Add Popup on Selecte Feature
Hi ,
I have Feature and i want to add Popup on that feature.I am able to add popup in case of Latitude and longitude but i am facing problem in case of when getting  feature .Please suggest me or if anyone have code please share me.
Regards:
 Rupesh
Hi Rupesh,
 I think you can find a sample named AddSimpleMarkers in our HowDoISamples, which maybe helpful for you.
 You can also view the other samples in it which related with "marker".
Hi Rupesh, I went though the same difficulty.  I found the demo code to be useless and had to find my own solution. Here is how I arrived at our solution.  I hope it helps. Sorry I am doing this in VB.NET because our project is VB.
First, I created a Mouse Click event handler for the map in my code.
Private Sub mapCtrl_MouseClick(sender As Object, e As MouseEventArgs) Handles mapCtrl.MouseClick
    'Code Goes Here
End Sub
I then added code to detect the right mouse click.
If e.Button = Windows.Forms.MouseButtons.Right Then
    'Code Goes Here
End If
Then I added code to get my mouse position.
Dim p As PointShape = ExtentHelper.ToWorldCoordinate(mapCtrl.CurrentExtent, New ScreenPointF(e.X, e.Y), mapCtrl.Width, mapCtrl.Height)
I would then loop through all of my InMemoryFeatureLayers and query for any features within 5 meters of my mouse pointer.  You can then place your own code to handle the returned features however you like.  In my case I dynamically built a Context Menu and set it’s location to the mouse pointer’s location.  If for some reason there are more than one feature within 5 meters I show a popup asking to choose between the features that were found.  I then show the menu from there.
For Each imfl As InMemoryFeatureLayer In layers
    Dim features As Collection(Of Feature) = imfl.QueryTools.GetFeaturesWithinDistanceOf(p, GeographyUnit.Meter, DistanceUnit.Meter, 5, ReturningColumnsType.AllColumns)
    'Code goes here to handle the features collection and show context menu or the like
Next
Here is how you can get set the location of a context menu to the mouse location.  This returns a point that can be used to set the location of the control.
mapCtrl.PointToScreen(New Point(e.X, e.Y))
I hope this was helpful.  This is how it looks in our application.
Hi Dave,
 Thanks for your share, that should be very helpful for Rupesh.
