Adding a javascript callback event after map posted in update panel
just as the title says
i am trying to get shoot a javascript method after posting the map inside an asp.net updatepanel
i am easly able to achive this for normal controls using my awesome javascript code
        //adds a javascript function to AJAX update panel callback routine
        //gets actionToTake (function to execute), id (submit button id to validate) (custom attribute)
        addAjaxCallbackEvent: function (actionToTake, id)
            //create script manager object
            var webform_ajax_manager = Sys.WebForms.PageRequestManager.getInstance();
            //add event
            webform_ajax_manager.add_endRequest(function (sender, arg)
                //if id is null run action normally
                if (id == null) {
                    actionToTake();
                //if not check the submit button id to match
                else if (sender._postBackSettings.sourceElement != null) {
                    if (sender._postBackSettings.sourceElement.id == id) {
                        actionToTake();
but it seems it doesnt work on ThinkGeoMap as it doesn't work as a simple ASP.NET control
how can I shoot a javascript method AFTER the thinkGeo AJAX Click Postback event?
I don't know how to do it using the style of code you posted, but I do it the following way:
In the server-side event, at the end of the method, put some code like this:
ScriptManager.RegisterStartupScript(Page, Page.GetType(), "scriptName", "methodToCall()", true);
The "methodToCall()" Javascript method will be run after the updatepanel has returned.
hmm , that is shorter
 thanks :P
Hi, Janet
 Thanks for your reply.
 Hope it resovle Arik’s problem. If you have more questions, please let us know.
 Khalil
