Adding a VectorTileLayer in blazor
Your Cloud Online Samples shows the javascript for adding a VectorTileLayer, however blazor does not have that same capability since the VectorTileLayer does not seem to exist. See the sample code here:
ThinkGeo Cloud Online Samples - Build Better Mapping Apps Faster.
I would like to do something similar in Blazor. Am I missing something?
James R.
Hi James,
There are now three options depending on what you want to render.
  1. In the current version, you can use the existing ThinkGeo Cloud vector maps overlay:
<MapView Id="map" MapUnit="GeographyUnit.Meter">
    <OverlaysSetting>
        <ThinkGeoCloudVectorMapsOverlay Id="thinkgeo-vector"
                                        ApiKey="YOUR_THINKGEO_CLOUD_API_KEY"
                                        MapType="ThinkGeoCloudVectorMapsMapType.Light" />
    </OverlaysSetting>
</MapView>
2. In the latest beta (v15.0.0-beta054), ThinkGeoCloudVectorMapsOverlay has been extended to support the newer ThinkGeo Cloud vector map style. The default is still V1 for backward compatibility. To use the new style, set StyleVersion to V2:
    <OverlaysSetting>
        <ThinkGeoCloudVectorMapsOverlay Id="thinkgeo-vector-v2"
                                        StyleVersion="ThinkGeoCloudVectorMapsStyleVersion.V2" />
    </OverlaysSetting>
</MapView>
3. The latest beta also adds a generic VectorTileOverlay for third-party vector tile services that
   provide a MapLibre/Mapbox-compatible Style JSON. For example:
    <OverlaysSetting>
        <VectorTileOverlay Id="third-party-vector"
                           StyleJson="https://tiles.preludemaps.com/styles/WorldStreets_Light/
                           style.json" />
    </OverlaysSetting>
</MapView>
Use ThinkGeoCloudVectorMapsOverlay when you are using ThinkGeo Cloud vector maps. Use
VectorTileOverlay when you want to consume a third-party MapLibre/Mapbox Style JSON vector tile
service.
I will try those out.
James R.
Just let us know if you see any issues.
Just to see if it worked, I tried testing the StyleVersion=“ThinkGeoCloudVectorMapsStyleVersion.V2” and got the following error(s):
warn: Microsoft.AspNetCore.Components.Server.Circuits.RemoteRenderer[100]
Unhandled exception rendering component: This vector tile overlay requires vectormap-v2.js to be loaded before the map is initialized.
Error: This vector tile overlay requires vectormap-v2.js to be loaded before the map is initialized.
at ThinkGeoMap.addOrUpdateVectorTileLayer (https://localhost:7297/_content/ThinkGeo.UI.Blazor/js/blazormap.n93kpjhp7j.js:676:23)
at Object.invoke (https://localhost:7297/_content/ThinkGeo.UI.Blazor/js/index.rl21mjusi9.js:61:23)
at b.processJSCall (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:4448)
at b.beginInvokeJSFromDotNet (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:4125)
at In._invokeClientMethod (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:69109)
at In._processIncomingData (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:66474)
at Ln.onreceive (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:60125)
at WebSocket. (https://localhost:7297/_framework/blazor.web.ej96puwv3k.js:1:84183)
Microsoft.JSInterop.JSException: This vector tile overlay requires vectormap-v2.js to be loaded before the map is initialized.
at Microsoft.JSInterop.JSRuntime.InvokeAsync[TValue](Int64 targetInstanceId, String identifier, JSCallType callType, Object[] args)
at A.K.A[A](IJSRuntime, String, Object[] args)
at ThinkGeo.UI.Blazor.ThinkGeoCloudVectorMapsOverlay.InitAsync()
at ThinkGeo.UI.Blazor.MapView.OnAfterRenderAsync(Boolean firstRender)
at Microsoft.AspNetCore.Components.RenderTree.Renderer.GetErrorHandledTask(Task taskToHandle, ComponentState owningComponentState)
fail: Microsoft.AspNetCore.Components.Server.Circuits.CircuitHost[111]
Unhandled exception in circuit ‘CPTxPZRcpyGnqiZESb5BJymHCrGenL2KBZ1LsgM_9mA’.
Never mind I needed the add the following in the correct location:
(formatted incorrectiy so the code would show)
script src=“https://cdn.thinkgeo.com/vectormap-js/4.0.0/vectormap.js”>
script src=“https://cdn.thinkgeo.com/vectormap-js/4.0.0/vectormap-v2.js”> */
Hi James,
Just FYI v14.5.3 was just released, the recent Blazor changes were included, here is the detail:
Changelog - ThinkGeo Docs
