Adding lines to multilineshape
Hi guys,
In addition to my previous post re removing lines from multilineshape, now I'm trying to add lines to an existing multilineshape using the following code:
private void AddLineToMultiLineShape(string lineLayerKey, string lineKey, string wellKnownText)
LayerOverlay lineLayerOverlay = (LayerOverlay)Map1.Overlays[DEFAULT_LINE_LAYER_OVERLAY_KEY];
InMemoryFeatureLayer lineLayer = null;
if (TryToGetLineLayer(lineLayerKey, out lineLayer, true))
if (lineLayer.InternalFeatures.Contains(lineKey))
MultilineShape multilineShape = (MultilineShape)lineLayer.InternalFeatures[lineKey].GetShape();
MultilineShape newLineSegment = new MultilineShape(wellKnownText);
for (int i = 0; i < newLineSegment.Lines.Count; i++)
multilineShape.Lines.Add(newLineSegment.Lines[i]);
lineLayer.Open();
if (lineLayer.EditTools.IsEditable)
lineLayer.EditTools.BeginTransaction();
Dictionary<string, string> columnValues = lineLayer.InternalFeatures[lineKey].ColumnValues;
lineLayer.EditTools.Update(multilineShape, columnValues);
lineLayer.EditTools.CommitTransaction();
else
lineLayer.Close();
throw new InvalidOperationException("The line layer not editable.");
lineLayer.Close();
else
throw new KeyNotFoundException("Line cannnot be found on the line layer.");
lineLayerOverlay.Refresh();
else
throw new KeyNotFoundException("Line layer cannnot be found on the line overlay.");
But the new lines are not being rendered on the map. I'm not sure if adding vertices to a lineshape is working either. As far as I remember, it used to work in the pre 16/11/09 build:
lineShape.Vertices.Add(vertex);
lineLayer.Open();
lineLayer.EditTools.Update(lineShape);
lineLayer.Close();
Thanks in advance,
Nirish
Hi Nirish,
Please try the following code:
    multilineShape.Id = lineKey;//add this line
Any questions please let us know.
That works. Thanks Johnny. So why does the ID have to be reassigned when Id property already has the old ID in it?
Hi Nirish,
When updating the feature, it creates a new Feature whose id equals the baseshape's id. If you don't input the id, the new feature will take a GUID as the new id, which is used to identify the old feature in lineLayer.InternalFeatures. Hope that explanation will help you.
