The adormamentscalelayer works as a charm now … Thank you!
I need a simple adormanentlayer that just displays a label on the map but don’t know where to start.
could you please share a sample to proceed ?
Thank you for your help.
Patrick.
Adornament layer
Hi Patrick.
Here is a very simple CustomAdornmentLayer class. Please use as following code and it will render a custom label in the center of the map.CustomAdornmentLayer customAdornmentLayer = new CustomAdornmentLayer();
androidMap.AdornmentOverlay.Layers.Add(“CustomAdornmentLayer”, customAdornmentLayer);
Howard
CustomAdornmentLayer.zip (548 Bytes)
Hi Patrick.
Howard
001_CustomAdornmentLayer.zip (548 Bytes)
